Engine will not start until five or more tries?
  • 52,797 POSTS
If the check engine light does not come on with key on, engine off, then there is an issue with the pcm. Check all fuses with test light to verify power. You may have a failed pcm
Monday, September 28th, 2020 AT 1:59 PM (Merged)
FLETCH721
  • 2001 HONDA ACCORD
Engine Performance problem
2001 Honda Accord 6 cyl 85000 miles
Recently my 2001 Accord has developed a problem where it fails to start. It is very intermittent which is causing a problem in finding the solution. When this does happen, the engine cranks, but it won't turn over. After 15 or 20 minutes the car will start.
I have been to the dealer and they can't replicate the problem. I have replaced the battery as well as the main relay and it is still going on. I am very frustrated!
KHLOW2008
  • 41,814 POSTS
Hi Fletch721,
Thank you for the problem.
Intermittent problems have to be diagnosed immediately when it occurs as it is at times difficult to replicate.
For non starting, it could be fuel or ignition taht is missing. When it occurs, test for sparks and fuel pressure and note which is missing.
MOOKITTY
  • 2001 HONDA ACCORD
  • 4 CYL
  • FWD
  • 11,300 MILES
I'm having a problem with the ignition on my 2001 Accord. Starting about 2 weeks ago after some rain, the car wouldn't start. The battery had some corrosion on the poles so I cleaned them and it started up. The problem keeps coming back. Sometimes it'll start up the first time, sometimes it takes 2 or 3 turns of the key to start. When it does start, there's no chugging or any indication of a problem. While running there's no problem either. I just took it on a 500 mile trip and not once was there a problem, except occasionally when starting. It seems to start better during the day when it's hot out. There is also a buzzing noise that has started at about the same time from around the glove box area. It seems to only make a noise when the accelerator is used.
KHLOW2008
  • 41,814 POSTS
Hi mookitty,
Thank you for the donation.
Symptoms for difficult starting indicates a possible fuel pressure drop scenario and if that is the case, the most common cause would be a leaking in-tank fuel filter, which is the fuel pump housing. When problem occurs, turn ignition switch on for 2 seconds. Turn Off and back on again for 2 seconds and try starting. If it is much easier to start, then you would need to check the filter.
A fuel pressure test would only be conclusive if a pressure gauge is attached and the fuel pressure is primed and left for at least 5 minutes to monitor the drop in pressure as the leak can be minimal and the pressure drops requires some waiting.
As to the buzzing noise, it most probably is a relay buzzing and it could be from the relays in the underhoos fuse box. You would have to locate the source to find out what is causing it.
MOOKITTY
Wouldn't a problem with the fuel pressure show when I'd be idling? I may not have explained the symptom right. When I start it acts as though the battery is dead. After trying it several times it will come straight on most of the time. The battery and alternator are good, I had them checked today. When I turn the key and it doesn't work, it makes a single click sound, nothing more. When I remove the gas cap, even when the car won't start, it depressurizes like it was before.
KHLOW2008
  • 41,814 POSTS
No, the leakage is only minimal and the fuel pump and pressure regulator are both able to maintain the pressure when the engine is running. This should not be applicable with the new data provided.
The ignition switch could be faulty according to your explanation. There was a safety recall on the component and from what I understand the recall is over but you can check with your local dealer regarding the problem.
The other possibility would be a failing starter motor. Disconnect the starter solenoid wire and use a remote wire to apply battery voltage. Test a few times to check if the starter cranks each and every time battery voltage is applied.
