HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Bronco
Engine
Symptoms
Not Running
SPONSORED LINKS
Will not start, NSS location
PREV
1
2
NEXT
MECHANIC
Yes, or it could be shorted internally.
You will need to remove it. I know you said the connector is stuck but you need to get it off without damaging it.
Friday, May 22nd, 2020 AT 6:52 AM
RGGBX
MEMBER
Okay, testing the NSS directly is obviously the next step. Let me work on that and get back to you.
Many thanks.
Richard
SPONSORED LINKS
Friday, May 22nd, 2020 AT 6:53 AM
MECHANIC
You are welcome.
Keep me updated.
Friday, May 22nd, 2020 AT 6:59 AM
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Will Not Start Without Starting Fluid
Truck Will Start With Starting Fluid (and Runs Great) But When I Shut It Off It Will Not Start Without The Starting Fluid. Pump Is...
Asked by
jaymonkey76
1990
FORD BRONCO
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1990 Ford Bronco Will Not Start When Raining
Electrical Problem 1990 Ford Bronco V8 Four Wheel Drive Automatic 100tho Miles The Bronco 1990 Full Size Will Not Start If It Is...
Asked by
wolfvenom1purple
1 ANSWER
1990
FORD BRONCO
1990 Ford Bronco Wont Start???????
I Have A 1990 Bronco That I Was Wrecked When I Bought It. It Ran Fine But When I Was Replacing Passenger Side Fender, I Forgot To Disable...
Asked by
leadhole
1990
FORD BRONCO
I Just Replaced The Battery And The Alternator. I Went To Start The Truck And It Will Not Start! If I Hold The Ignition Forward With The Key...
Asked by
joshuaepling
1990
FORD BRONCO
The Other Day My Car Broke Down On Me And It Wont Start, We've Been Told To Check The Coil And The Coil Is Fine It Turns Over But It Wont...
Asked by
draymond
1990
FORD BRONCO
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
