When I got the car it ran fine then. I noticed one day it was shaking a little much and went had had it check and it was having a multiple misfire reading.
I figured the car is old maybe some new spark plugs and wires were needed so I changed them and did not change anything. then I replaced all three ignition coils and still nothing. then I saw on YouTube that you can see if the coils are not firing and the coil for two and five were not firing. they are on the same coil and the day after I was getting no spark. car does not start, turns over but does not start. it is not getting any spark.
Can it possibly be the ignition control module or something else?
Mar 18, 2018 at 1:50 PM
