Fuel pump relay?
WRIGHTDODGE
  • 1996 DODGE RAM
Electrical problem
1996 Dodge Ram V8 Four Wheel Drive Automatic
my fuel pump wont prime I have power going to pump but thats it I have checked relays and fuses they are good bought new fuel pump does the same thing all of this stemed from me changing the tranny in truck
Tuesday, August 25th, 2020 AT 5:13 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure fuel pump is grounded good. The PCM may be faulty, did you replace tranny with same make and model?
JDOUGH1
  • 1988 DODGE RAM
  • V8
  • 4WD
  • 96,000 MILES
I attempted to start my 1988 Dodge Ramcharger and it kicked over once and died. During subsequent attempts I did not hear the normal hum of what I believe to be the fuel pump. Does that seem like a likely issue and if so do I look at the relay, cable, fuel pump etc? Is the fuel pump in the tank? Thanks
MERLIN2021
  • 17,250 POSTS
Chrysler was a bit slow entering the fuel injected world, if you have FI and not a carb, then the pump is in the tank. Spray staring fluid, sparingly into the intake, will it start briefly? If so suspect the pump! Or the relay.
JDOUGH1
