1986 Dodge Ram 150 Fuel Pump No Power
RANDAL
I have a 1986 dodge ram 150 4 x 4. I can not seem to get power from the auto shutdown relay to the fuel pump in the tank.. If that is the way it is supposed to work.. I followed the two electrical lines from the pump and ended up at this auto shutdown relay. I can put power straight from a electrical source and the pump runs, but no luck other wise Thank you
Jan 16, 2006 at 2:01 PM
2CARPRO JACK
  • 11,533 POSTS
Try the ignition switch , it should power the relay
Jan 18, 2006 at 8:43 AM
RANDAL
When i turn on the ignition switch i do get power to the relay but not to the pump is this the way this relay works
Jan 19, 2006 at 12:54 PM
XJETMECH
  • 12 POSTS
Power should go from the auto shutdown relay to the fuel pump relay (probably on the same bracket), so the problem could be with the pump relay. Down side,,,,,,, the computer supplies the ground for both.
Mar 15, 2006 at 8:58 AM
Suggested Repair
Confirm the ignition switch is supplying power to the auto shutdown relay, then check that power continues from that relay to the fuel pump relay, which is likely on the same bracket. The fuel pump relay may be faulty. Also verify the computer ground for both relays, since the computer supplies that ground.
Conversation Summary
The owner of a 1986 Dodge Ram 150 4x4 cannot get power from the auto shutdown relay to the in-tank fuel pump, although the pump runs when powered directly. One expert advised checking the ignition switch because it should power the relay. The owner then reported power at the relay with the ignition on but still no power to the pump. Another reply said power should go from the auto shutdown relay to the fuel pump relay, so that relay may be the problem, and noted that the computer supplies the ground for both relays.
