1986 Nissan 720 Clutch Adjustment Fix
JOKER1972
How do you adjust the clutch on a 1986 Nissan 720 4x4 pickup?
Oct 11, 2007 at 4:04 PM
  • 55,865 POSTS
Start by locating the push rod that goes into the clutch master cylinder. Then loosen the jam nut on the rod, loosen rod so the pedal has play then tighten the nut and you are all set.
Best, Ken
Apr 17, 2017 at 10:14 AM
Suggested Repair
Locate the push rod at the clutch master cylinder. Loosen the jam nut, adjust the rod so the clutch pedal has play, then tighten the jam nut.
Conversation Summary
The owner asked how to adjust the clutch on a 1986 Nissan 720 4x4 pickup. The expert said to find the push rod at the clutch master cylinder, loosen the jam nut, adjust the rod until the pedal has play, and then tighten the nut.
