'92 Nissan 240sx clutch problem
1992 NISSAN 240SX
M45
I have a '92 Nissan 240sx and the clutch is stuck in the down position. You can pull it up but when you press on it it immediately snaps back down and stays down. I had noticed that the clutch seemed to be "sticking"
a bit when shifting, prior to this. And sometimes the car has been hard to shift into 1st and reverse. I tried adding clutch fluid but the clutch is still stuck down. Is this going to be expensive to fix or is it not a big deal? Thanks.
-M45
Jan 6, 2007 at 1:43 PM
Check the clutch slave, bleed it a few times-like bleeding the brakes.and try the clutch again-if its a no-go inspect the clutch M/C.
HTH- Good Luck!
Jan 6, 2007 at 4:24 PM
RYANNICO
Have you checked for binding in the pedal linkage, cable, crossshaft, fork or pivot ball? A worn seal on your hydraulic system can also be a reason.
Feb 28, 2007 at 4:17 PM
