1989 Nissan 240SX gears
1989 NISSAN 240SX
PINOY_STYLEZ
Transmission problem
1989 Nissan 240SX 4 cyl Two Wheel Drive Manual
i own a 1989 nissan 240sx and when i shift into 5th gear and somtimes when i shift in to reverse, it tends to pop out, what may be causing this problem, i hope to hear from you soon thanks
Sep 9, 2008 at 7:48 PM
  • 31,937 POSTS
HI there,
check that the gear box is bolted up tight first, if that is ok, this will be a fault in the selector hub or a broken or weak détente spring in the selector if reverse is opposite 5th gear on the selection patten i would be thinking a détente problem first.
Mark (mhpautos)
Sep 9, 2008 at 11:32 PM
