How do you adjust the clutch on a 1986 Nissan 720 4x4 pickup?
Oct 11, 2007 at 4:04 PM
Locate the push rod at the clutch master cylinder. Loosen the jam nut, adjust the rod so the clutch pedal has play, then tighten the jam nut.
The owner asked how to adjust the clutch on a 1986 Nissan 720 4x4 pickup. The expert said to find the push rod at the clutch master cylinder, loosen the jam nut, adjust the rod until the pedal has play, and then tighten the nut.
