1995 Nissan Truck no start
DYYDJBB
  • 1995 NISSAN TRUCK
Engine Mechanical problem
1995 Nissan Truck 4 cyl Four Wheel Drive Manual
I just short blocked a nissan 2.4L. I have 175psi comp. Each cylinder, 40psi fuel pressure to the regulator and good spark, but it will not start. One thing I did notice is the tach is not moving during crank. Could this be along the lines of whats wrong? Any suggestions?
Wednesday, November 12th, 2008 AT 7:00 AM
Fuel and spark okay-check the engine valve timing
Wednesday, November 12th, 2008 AT 9:30 AM
DYYDJBB
  • 7 POSTS
There is a new timming chain, guides, and tensioner. When first put together it ran for about 10 minutes and then turned off like someone turning off the key.
Wednesday, November 12th, 2008 AT 10:34 AM
Inspect and test the ECCS relay and distributor camshaft position sensor
Wednesday, November 12th, 2008 AT 12:05 PM
DYYDJBB
  • 7 POSTS
I will check both tonight. I found diags on how to check the cam sensor and eccs relay but could not find anything to locate the eccs relay, can you tell me where it is? Should it be labeled? There is a blue relay right by the ignition coil, is that it?
Wednesday, November 12th, 2008 AT 12:55 PM
DYYDJBB
  • 7 POSTS
Terminal d on sensor in dist is erratic. I am checking with nissan for the part today and will let you know.
Thursday, November 13th, 2008 AT 6:40 AM
DYYDJBB
  • 7 POSTS
R/r distributor because cam sensor was not available. Engine runs good. Thank you!
Monday, November 17th, 2008 AT 7:06 AM
