Sounds like the NapZ engine my type-8 Hododas!
Okay-did you hook up the battery correctly meaning positive to positive and negative to negative-if not you blew the fusible links If its connected properly and you are seeing sparks, connections is still loose. Or you got it backwards-double check it then comeback.
SPONSORED LINKS
Tuesday, January 15th, 2008 AT 2:50 AM
