1992 Nissan Truck Will not start
SHANAG
  • 1992 NISSAN TRUCK
  • 4 CYL
  • MANUAL
  • 285,000 MILES
Ok I have a 1992 manual nissan truck. It will not start and the only to get it started is to push start it. I took off the starter and had it tested they said it was good. I had the battery tested also and it was good. What could be the issue?
Thanks
Monday, September 29th, 2008 AT 7:05 PM
Jumper the clutch switch and see what happens
Monday, September 29th, 2008 AT 7:09 PM
SHANAG
Rasmataz,
Thank you for replying. We did try that yesterday and that didn't work. Could the solenoid be bad?
Wednesday, October 1st, 2008 AT 8:49 PM
Check for power at the starter solenoid when key at run position -power there-replace the starter-not there-test the ignition switch
Thursday, October 2nd, 2008 AT 9:49 AM
