1997 Nissan Pathfinder won't start
BOBSLOAN
  • 1997 NISSAN PATHFINDER
  • 6 CYL
  • 4WD
  • MANUAL
  • 109,000 MILES
The car won't start and the battery is good. There is no response when I turn the key. The dealer checked it last summer for the same problem but couldn't find anything. I suspected the clutch relay switch and had them replace it.
Tuesday, December 18th, 2007 AT 8:51 AM
The car won't start and the battery is good. Do you mean it cranks over and refuses to start or it doesn't crank over at all.
If it cranks over and will not start I'll be checking into the ignition and fuel system
Tuesday, December 18th, 2007 AT 9:02 AM
