1997 Nissan Pathfinder Just won't start!
DARIN33
  • 1997 NISSAN PATHFINDER
  • 6 CYL
  • 4WD
  • 180,000 MILES
My 1997 pathfinder always worked great, then one morning it just wouldn't start. Changed fuel filter, distributor(includes coil, cam sensor, cap), crank sensor, ECM. Fuel pressure OK, checked for obvious broken wires or bad grounds. Injectors are not opening, no fuel to cylinders. Compression OK, spark OK. Driving me nuts! HELP PLEASE.
Saturday, August 9th, 2008 AT 8:22 PM
Check for power at the injector connectors red and white wire, No power there test the ECCS relay located in right side of engine compartment in relay box it powers the injectors-Power at the red and white wire at injectors-you have a problem with computer ground drivers for the injectors
Saturday, August 9th, 2008 AT 8:36 PM
