1997 Nissan Maxima Will not start up
JTATEM
  • 1997 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 180,000 MILES
My car has had I start up problem for 3 months now, it always took a couple key turns before it started, now it just wont start up at all, all the lights inside come on when its in accessory postion, and I tryed to jump it and nothing. One thing, in the past when it did start up, sometimes the overdrive light would flash several times right when I would start it up. Thanks for your time.
Wednesday, December 23rd, 2009 AT 10:02 AM
RACEFAN966
  • 5,029 POSTS
Have you checked for fuel or spark? If not check if it has spark, simply unplug a spark plug wire and put a screwdriver in the end and put close to metal and crank is there spark. It there is spark then you will need to see if there is fuel. Here I would get some throttle body cleaner and spray it in the throttle body and see if it starts. If it does then I would check fuel pressure as it may be the fuel pump, this would also explain the hard starting prior to this. Let me know what you find.
Wednesday, December 23rd, 2009 AT 10:45 AM
