1997 Nissan Maxima will not start
JETA81
  • 1997 NISSAN MAXIMA
I have a 1997 Maxima with 215,000 miles. Auto 2 wheel that does not want to start in any weather. The battery, starter and altinator were replaced in aug of 06, that is the 3rd time they were replaced since we have owned the car new. In order to get car to start, I have to wiggle the shifter, and the steering wheel. This will usually get her to start after awhile. The car has been like this since we purchased it, but it is getting progressivly worse. Now it takes about an hour of doing this to get it to crank over. Per dealer they have a sercurity feature that the car has to be in park to get it started, we need to wiggle shifter and it should be fine. We have done this for the past 10 years, and it is not working anymore. There are no other issues once the car starts, there is not problems driving. When you turn the key there is nothing, but the battery is not dead, we did take that as well as the started to autozone and had it tested. Any sugestion would be appreciated, or if you need any additional ifo please let me know.
Friday, June 8th, 2007 AT 3:08 PM
KIN CHAN
  • 453 POSTS
Sounds like the safety neutral inhibitor system is not engaging at park. Try to place the shifter at neutral. If it start then take it to an ASE mechanicindependent shop. This should be fairly easy.I fixed plenty of mumbo jumbo wingers job from dealership.
Good luck man
Friday, June 8th, 2007 AT 5:17 PM
JETA81
We have tried it in netural and park, we have checked all of the fuses under the hood, and nothing. If the car sits for a few days, it will start up w/o a problem. Its when you try and start it more that approx 2 times a day, there is a problem.
Saturday, June 9th, 2007 AT 3:15 PM
JETA81
We checked out that netural stich, and that is fine as well. I also check all relays. The console on the car as well as the stearing colom have been taken apart, and everything that we can think of has been check with no luck. Do you have any other sugestions?
Monday, June 11th, 2007 AT 7:23 AM
