1997 Nissan Maxima Will not start
WTEEBUCK
  • 1997 NISSAN MAXIMA
Engine Performance problem
1997 Nissan Maxima 6 cyl Front Wheel Drive Automatic
My engine cranks but will not start. Has been a little hard to start before quiting. Battery and starter are good.
Sunday, March 7th, 2010 AT 8:15 PM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, March 8th, 2010 AT 12:38 AM
