1997 Nissan Altima. 140,000 Starting Problem
INJUNINUS
  • 1997 NISSAN ALTIMA
I was driving the car one day and the doors started locking/unlocking and then it stalled. I got the alternator and battery replaced. Yesterday while I was driving the airbag light was flashing and the radio started to turn on and off and after a few minutes the car stalled. I was able to start the car back again but it would stop as soon as I turn the lights on or use the indicators. Any help in figuring out the problem is highly appreciated.
Thanks
Thursday, January 18th, 2007 AT 12:08 PM
JCROW
  • 13 POSTS
Was your car previously water damaged or burned? Sounds like you have major electrical problems.
Maybe you have some wires that are worn and they are touching and almost 'shorting out'? I don't know anything about electrical. (*Please DISCONNECT THE NEGATIVE TERMINAL if you want to go crawling around looking for worn wires*)
All I can suggest is find a small town mechanic and see if he won't trouble shoot with you. Most of the times they don't charge you if they don't do anything. And other times it is only a small charge of around 20$. Another suggestion is to pick up the Haynes or Chilton book on it. (Haynes being the better of the two- I ThInK-- but Chilton should be good if you are just a mechanic when you have to be.)
Sorry man, good luck with it.
Tuesday, January 30th, 2007 AT 7:55 PM
