1997 Nissan Altima Won't Start
SERCANET
  • 11 POSTS
97 Altima GXE 2.4L ac at pw pl 127K mi.
Wouldn't start a few days ago, even though it turned over normally. After some persuasion, got it started and it ran a bit, then stalled. Several times. Each time was harder to start. Now it won't start at all, but still truns over fine. Changed fuel filter. Checked spark at each cylinder, all good. Spraying starter fluid into air intake had no effect. Power transistor, MAF sensor, EGR sensor all test good electrically. Scanner shows no codes. Distributor was replaced a few thousand miles ago (new cap and rotor), and there is no oil in the optical sensor plate now. Fuel comes out of disconnected fuel line and can hear fuel pump running at key on.
These are just some of the things I've tried. Fuel pump maybe? How come starter fluid didn't make it fire?
Any ideas?
Update: Connected a fuel pressure gauge and it shows almost 50 psi. This is getting aggravating.
Oct 9, 2007 at 12:22 PM
FISHERMAN
  • 937 POSTS
[quote:caf6b414e5="sercanet"]97 Altima GXE 2.4L ac at pw pl 127K mi.
Any ideas?
Update: Connected a fuel pressure gauge and it shows almost 50 psi. This is getting aggravating.[/quote:caf6b414e5]
Hello
check for spark disconnect one of the spark plug cable and check it for spark (do it with care)
let us know on your findings..
Oct 10, 2007 at 11:39 AM
SERCANET
  • 11 POSTS
[quote:c4e9ea3302="fisherman"][quote:c4e9ea3302="sercanet"]97 Altima GXE 2.4L ac at pw pl 127K mi.
Any ideas?
Update: Connected a fuel pressure gauge and it shows almost 50 psi. This is getting aggravating.[/quote:c4e9ea3302]
Hello
let us know on your findings..[/quote:c4e9ea3302]
Got it running by advancing the timing a bit, but it's rough and stalls easily. I'm going to try new plugs and dist. cap/rotor. I'll let you know.
Oct 10, 2007 at 11:48 AM
FISHERMAN
  • 937 POSTS
OK sounds good
do you have the spark plug wires on the right order?
let us know..
Oct 10, 2007 at 12:08 PM
SERCANET
  • 11 POSTS
[quote:be5de5d600="fisherman"]OK sounds good
let us know..[/quote:be5de5d600]
Yep. Never disconnected them from the distributor cap and the other ends are pretty hard to mix up, being all different lengths.
Oct 10, 2007 at 12:15 PM
FISHERMAN
  • 937 POSTS
[quote="sercanet"][quote:c499d43827="fisherman"]OK sounds good
let us know..[/quote:c499d43827]
Yep. Never disconnected them from the distributor cap and the other ends are pretty hard to mix up, being all different lengths.[/quote
Ok replace the spark plugs wires cap and rotor and we start from there..
did you "mark" the distributor position before advance the timing?
Oct 10, 2007 at 12:34 PM
SERCANET
  • 11 POSTS
[quote="fisherman"][quote:8c629f02e3="sercanet"][quote:8c629f02e3="fisherman"]OK sounds good
let us know..[/quote:8c629f02e3]
did you "mark" the distributor position before advance the timing?[/quote:8c629f02e3]
There's a reference mark on the head and a V-shaped notch on the distributor body that indicate normal setting. I'll get back when I get the plugs and such changed.
Oct 11, 2007 at 12:10 AM
SERCANET
  • 11 POSTS
[quote="sercanet"][quote:4afefff367="fisherman"][quote:4afefff367="sercanet"][quote:4afefff367="fisherman"]OK sounds good
let us know..[/quote:4afefff367]
did you "mark" the distributor position before advance the timing?[/quote:4afefff367]
There's a reference mark on the head and a V-shaped notch on the distributor body that indicate normal setting. I'll get back when I get the plugs and such changed.[/quote:4afefff367]
Finally got back to it, after being pulled away on other stuff for a few days, and asked my daughter (it's her car) when she bought gas last. Answer: the night before it wouldn't start. So I siphoned as much of the gas as I could and put in five gallons of fresh gas and a bottle of Gumout injector cleaner. It seems to run fine now, but the Air Bag light on the dash is flashing now. What's up with that? If it isn't one thing it's another.
Oct 14, 2007 at 7:49 AM
Suggested Repair
The no-start was resolved by draining fuel bought the night before and refilling with fresh gas plus injector cleaner. Also verify spark, plug-wire order, and distributor timing marks; the expert suggested plugs, wires, cap, and rotor if ignition parts are suspect. The flashing airbag light was not diagnosed.
Conversation Summary
A 1997 Nissan Altima GXE 2.4L cranked but would not start, then ran roughly after the timing was advanced. Spark, fuel pressure near 50 psi, and plug-wire order checked out, with no codes. The expert advised confirming spark and wire order, marking distributor position, and replacing plugs, wires, cap, and rotor. The owner later learned fuel was purchased the night before the failure, drained it, added fresh gas and injector cleaner, and the engine then ran fine. A flashing airbag light remained unexplained.
