First Off I work on cars fairly often and am trying to learn as much as possible. The car wants to turn over but just won't. The check engine light and the oil light comes on. I checked the oil and it is fine. I really want to find out the trouble code but I have no way to get it to Autozone to do so. My dad thinks that it might be the fuel pump but I have no way of checking. I have the Chiltons book so if you have any ideas on what it might be I can check the book for a possible solution.
SPONSORED LINKS
Monday, December 3rd, 2007 AT 7:19 PM
BLACKOP555
MECHANIC
Try starting fluid sprayed int he throttle body. Does it start right up and run or does it start up and die or not start at all. Post back your results.
Monday, December 3rd, 2007 AT 7:22 PM
RARTUIN270
MEMBER
I tried that and it simply did not start. Same as before, someone told me the other day to try the fuel filter. Thats what I am going to try next
SPONSORED LINKS
Monday, December 10th, 2007 AT 2:24 PM
BLACKOP555
MECHANIC
If you use starting fluid or gas in the tb or a gas soaked rag, it should fire right up, for that reason check the ignition timing and spark from each plug, they should be bright and blue.
