My car is not start it's only cranking
40,500 MILES
FAYE123
  • 5 POSTS
My car is not starting up it's only cranking here is what happened
If I tap the key in the start position but don't hold it. The vehicle will continue to crank for so much time. But doesn't start at all .
I found an error code was P0703
Sep 9, 2013 at 4:58 AM
HMAC300
  • 48,601 POSTS
that codes I for a brake light switch problem and shouldn't effect starting.is this a gas or diesel engine? It might still be covered under warranty if you have the exteneded warranty with it.
Sep 9, 2013 at 5:13 AM
HMAC300
  • 48,601 POSTS
I forgot check the fuel pressure first.
Sep 9, 2013 at 5:14 AM
FAYE123
  • 5 POSTS
it's diesel no its out of warranty , and I also got this error code U0155,U0100
Sep 9, 2013 at 5:36 AM
HMAC300
  • 48,601 POSTS
I was kind of afraid you were going to say diesel. I am not a diesel guy but have your battery/batteries checked for condition as well as load test. auto parts do this for free. then look at the fuses in the pic this box is underhood you can test them with a test light and they should light on both sides also check the pcm relay because the one code is that the ecm has lost communication so that may be your problem. Also try resetting your anti theft unit it should tell you how in manual as we don't have instructions for that only to fix them. also with the u0155 code you may have lost the fuel prime so if youspray choke cleaner in air duct and it starts then it's a fuel problem. but for the other problem of a no start it needs a pro type scanner hooked to the it to test other areas..
Sep 9, 2013 at 6:05 AM
FAYE123
  • 5 POSTS
To be honest with you i'm in Africa ( Djibouti) they don't have a dealer there . But I have OTC Geysis scanner tool , and I also have Ease reprogramming .
1- for U0155 code i replaced the fuel prime and still didn't work
2- I have Ease tech get into my computer to reprogram the PCM and he said it reprogramed
3- canu send me the fuses pic cause i don't see anything
4- How do i reset the anti theft can you instruct how please
5- since you not a diesel guy do you anyone else can help or i can call please
Sep 9, 2013 at 7:41 AM
THIS IS MIKE
  • 686 POSTS
Here are the code definitions
P0703 Torque Converter/Brake Switch B Circuit Malfunction
U0100 Lost Communication With ECM/PCM "A"
U0155 Lost Communication With Instrument Panel Cluster (IPC) Control Module
I will have another expert take a look at this problem for you.
Sep 9, 2013 at 9:25 AM
THIS IS MIKE
  • 686 POSTS
It sounds like it could be a battery problem. Sometimes when batteries get low on charge or are failing, they don't have enough power to disengage the starting circuit. Have the batteries load tested.
Sep 9, 2013 at 9:57 AM
SATURNTECH9
  • 30,868 POSTS
What size engine do you have?Is the security light on solid or flashing with the key in the run position?Also what does the high pressure oil pressure read on the scan tool while cranking?Also have you checked for water in the fuel filter etc?Air in the fuel lines?how long ago did you replace the fuel filter?
Sep 9, 2013 at 11:37 AM
THIS IS MIKE
  • 686 POSTS
The instrument cluster is the most intelligent computer on the vehicle, and if it doesn't work, nothing else will. It is what tells all the other computers to turn on. It has to be a compression or timing problem. Real slow cranking could be considered a compression problem if you want to get technical, but that would explain the no-start condition. If the ecm is not communicating with the engine the fuel will may not be delivered as it should and not start.
Sep 9, 2013 at 11:41 AM
RIVERMIKERAT
  • 6,106 POSTS
The 2 "Lost Communications" errors are probably where this problem lies.
1: Check and clean the connectors to the ECM and instrument cluster.
2: Check the grounds for these two items.
3: Check the wiring to the ECM and instrument cluster.
4: Listen carefully when you crank the engine?can you hear the fuel pump engaging?
5: Find the fuel pressure test port inside the engine compartment. Crank the engine and then carefully push the valve in the port, shielding your eyes and mouth. If no fuel sprays, you have a pump problem or air in the lines.
Sep 10, 2013 at 12:37 AM
FAYE123
  • 5 POSTS
I have the video for you all so you can get the idea of what i'm talking about
Sep 10, 2013 at 1:23 AM
FAYE123
  • 5 POSTS
I have the video to see what i'm talking about but i can't send it here it doesn't go through . is there any way i can send the video of the truck
Sep 10, 2013 at 1:55 AM
THIS IS MIKE
  • 686 POSTS
If you upload the video to youtube you can post the link here
Sep 11, 2013 at 6:39 AM
