2000 Ford F350 motor will turn over but will not start
2000 FORD F-350
240,000 MILES • V8 • 4WD • MANUAL
ERICAESTES
  • 6 POSTS
Got truck in some water but did not sink but half of the motor--replaced cam sensor and still will not crank--what might it be?
Dec 23, 2007 at 10:35 AM
SERVICE WRITER
  • CERTIFIED EXPERT
  • 9,123 POSTS
The very first thing I would do is to see if the engine chan be turned over by hand. Use a breaker bar and a socket and try to turn the engine over manually by placing it on the crankshaft.
You may have hydorollically locked the motor.
Dec 23, 2007 at 10:40 AM
ERICAESTES
  • 6 POSTS
It will turn over fine by the ignition switch--it just won't crank up--what would be the difference in doing it manually!!
Dec 23, 2007 at 11:38 AM
SERVICE WRITER
  • CERTIFIED EXPERT
  • 9,123 POSTS
We had a communication problem.
Cranking and turning over are symonomous.
I thought you meant no crank.
Safe to assume there is just no spark on this?
Dec 23, 2007 at 11:45 AM
ERICAESTES
  • 6 POSTS
sorry, forgot to say that it is a diesel 7.3 powerstroke
Dec 23, 2007 at 11:55 AM
ERICAESTES
  • 6 POSTS
Do you have any idea what the problem might be??
Dec 23, 2007 at 12:14 PM
ERICAESTES
  • 6 POSTS
Paul, are you still there??
Dec 23, 2007 at 12:46 PM
SERVICE WRITER
  • CERTIFIED EXPERT
  • 9,123 POSTS
Yes Sorry...
Wine and women...;-) know what I mean :-).
Uhh it is the holidays!
Let me do a little research. and I'll re-post, I am not familiar with the diesels, other than the diesel father's mysterious death.
Dec 23, 2007 at 12:55 PM
SERVICE WRITER
  • CERTIFIED EXPERT
  • 9,123 POSTS
https://www.2carpros.com/forum/automotive_pictures/30961_die_1.jpg
I am going into unchartted waters with this help, but surely will be a resource.
https://www.2carpros.com/forum/automotive_pictures/30961_die_2.jpg
Dec 23, 2007 at 1:03 PM
ERICAESTES
  • 6 POSTS
thanks for trying but we were looking for someone s little more experienced with diesel engines
Dec 23, 2007 at 8:23 PM
SERVICE WRITER
  • CERTIFIED EXPERT
  • 9,123 POSTS
I am trying to get hold of another mod that is, hoping he can help out, I will make a post to alert a few other mods that may be of assistance.
I'm just not the right one on this particular situation.
Dec 23, 2007 at 8:40 PM
  • CERTIFIED EXPERT
  • 31,937 POSTS
Hi there,
First thing to do is a compression test, It is a real possibility that you have compressed a rod, Now this will not stop it from running but if you have a deficient compression it is a waste of time going any further. Apart from that, back off all the injector lines and crank, you should have fuel pulsing, if not there is a problem with the injector pump. start there, now i will be around on and off over the Xmas break so i will try and catch up with any posts you make.
Mark (mhpautos)
Dec 23, 2007 at 8:53 PM
