I have a 1998 Mitsubishi Eclipse that just got the timing belt replaced, do to it snapping. I got a compression test ran on the cylinders & the 2nd cylinder is reading 0 lbs. Would i be able to drive it up to 20-25 miles to get it home; that way i can have a friend, take apart & rebuild the head, because only 3 cylinders are running.
Feb 17, 2009 at 12:23 PM
