1996 Mitsubishi Eclipse no spark {possible timing belt}
LNS711
  • 1996 MITSUBISHI ECLIPSE
  • 4 CYL
  • FWD
  • 11,700 MILES
I was driving on freeway, check engine light came on within 2 miles she died, towed home found oil n plugs, replaced valve cover and o rings, and plugs. Went to start "no spark" got a poping sound from throttle harness by sensor plug, did dash code recovery got {1} beep {2} beeps{5}beeps {5}, took it to a shop they said they think it's timing belt jumped, will that cause it to have no spark?Mitsubishi told me that the car won't start because the computer won't let it. I don't get it why would the timing belt stopp the car from having spark?
HELP HELP HELP
Thursday, September 4th, 2008 AT 5:32 AM
2CARPRO JACK
  • 11,533 POSTS
Getting the codes is done by watching the flashing check engine light, not sure what beeps you counted. Get the codes by doing this- Turn key, on, off, on, off, on within 5 seconds. The light will flash the codes, example. 4 long flashes and then 3 short ones is a code 43. A timing belt that has jumped wont stop it from having spark. Does the engine sound normal when cranking or does it sound fast, then slow or jumpy?
Saturday, September 6th, 2008 AT 8:26 AM
LNS711
It sounds weak, like its dragging, I also got shocked from wire harness by the timing belt cover, I really dont think its timing belt, I think it might b electracal, the flashes I got from dash r 1 2 5 5 what does this mean
Saturday, September 6th, 2008 AT 6:18 PM
2CARPRO JACK
  • 11,533 POSTS
The codes need to be counted by length of flashes. Long flashes are 10's short flashes are 1's. Assuming they are all short flashes the codes I show are
1-No cam position sensor signal at PCM
2-Internal; PCM failure (powertrain control module)
5-Charging system voltage low
Verify cam is turning when you crank the engine. If so you may have a bad PCM
Sunday, September 7th, 2008 AT 8:34 AM
