Usually if an injector isnt firing, it will run poorly even cold, but tou can try starting the engine, unplug each injector 1 at a time, the rmp should drop about 100 rpm momentarily, if this happens at each injector, they are working OK, plug the unplugged one back in and then go to the next one. You might also clean out the throttle body with throttle body spray cleaner, follow the directions on the can.
SPONSORED LINKS
Monday, May 10th, 2021 AT 11:22 AM
(Merged)
