2001 Ford F150 V6 Two Wheel Drive Automatic 130000 miles
Engine missfires at gentle acceleration. Codes read lean fuel mixture right bank and lean fuel mixture left bank. I have tried coil pak, plug wires, plugs, fuel filter. Also, valve rattle when engine is warm at low rpm under load. Can you help me with this problem? Thank you
SPONSORED LINKS
Tuesday, December 4th, 2007 AT 6:44 PM
