SRS LIGHT
  • 31,937 POSTS
If the battery was disconnected, you may have to do a base idle re set.
Saturday, February 9th, 2019 AT 8:06 PM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
  • 2006 HONDA ACCORD
  • 88,000 MILES
When I turn the ignition switch on, the Air bag lights come on and it says their all OFF, then All the lights go off as they should. Should the Air Bag Lights at some point say that they are ON?
DOCHAGERTY
  • 9,601 POSTS
I think what you are seeing is the normal start up routine.
LAVELLE
  • 2002 HONDA ACCORD
  • 4 CYL
  • FWD
  • 125,000 MILES
Why does the "SRC" light come on? Also, why does the airbag light come on sparingly?
  • 31,937 POSTS
HI there,
the first thing you should do is run a scan to check for any set fault codes, the light à  n, is an indication that a fault has been located in the system, start here.
Mark (mhpautos)
