Changing spark plugs
DAVE1968
I would suggest replacing your plenum gasket also if you go that route. It's not very hard to do, just basic r&r.
Monday, November 26th, 2018 AT 12:20 PM (Merged)
DONNANNEMAN
  • 1996 MERCURY SABLE
How do I get to the spark plugs on firewall side of engine?
I haveread rthat I need to remove part of intake manifold, Fellow at parts store suggested I disconnect exhaust and one engine mount to tilt engine forward and access plugs that way.
I also need to replace O2 sensor on that bank.
MERLIN2021
  • 17,250 POSTS
I would leave the exhaust alone and get the gasket set for the tune up. You let a flex pipe this old hang and you WILL be replaceing it! If it makes you nervous to take an intake off give the job to someone else. Cheaper in the long run.
KAREN71165
  • 2003 MERCURY SABLE
Engine Performance problem
2003 Mercury Sable 6 cyl Front Wheel Drive Automatic
How to change spark pugs that are under the manifold on a 2003 Mercury Sable
JGAROFALO
  • 489 POSTS
Remove the upper section of the manifold for access to the spark plugs.
EMERALDLADYHUSKY
  • 1995 MERCURY SABLE
  • 6 CYL
  • 4WD
  • 150,000 MILES
I jusy recentaly bought a 1995 mercury sable an I did a transmission flush and an oil change plus an tune up and bought new plugs for the sparks plug and wires what could it be now. Also the odometer works for a minute and the next it stops
BLACKOP555
  • 10,371 POSTS
What seems to be your problem/
was teh odometer messed up before you did the tranny change?
When you say odometer do you mean speedometer or tachometer, or infact the odometer, thing that shows your miles traveld?
WILLIES54
  • 2001 MERCURY SABLE
  • 6 CYL
  • FWD
  • 115,000 MILES
How are the rear spark plugs/wires accessed?
Wednesday, December 5th, 2018 AT 10:08 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
On this car you must remove the engine torque mounts and roll the engine forward held by a block of wood. Here is a guide to walk you through the steps on replacing the plugs.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Cheers, Ken
Wednesday, December 5th, 2018 AT 10:09 AM (Merged)
WILLIES54
Sorry about the lack of info. 24 Valve DOHC 3.0 L engine. Looks like the intake will have to come off, but I wasn't sure if you accessed it through the interior or by removal of the intake system. The engine mount tip was great. I just put it in park and moved the car moved the engine right over, plenty of room.
BMRFIXIT
  • 19,053 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
