Mercury Heater Core Hose Bypass Fix
MERCURY
SCOOTER1976
How do I plug off the lines to the heater core hoses and where are the located?
Mar 10, 2007 at 3:26 AM
MERLIN2021
  • 17,250 POSTS
The heater hoses go from the motor to the firewall.
they will be about 3/4" I don't suggest pinching them off. Take the clamps off at the firewall and put them together so your anti-freeze will circulate!
Mar 10, 2007 at 12:05 PM
Suggested Repair
Do not pinch off the heater hoses. They run from the engine to the firewall and are about 3/4 inch. Remove the clamps at the firewall and connect the hoses together so coolant continues to circulate.
Conversation Summary
The owner asked how to plug the heater core hose lines and where they are located on a Mercury. The expert said the hoses run from the engine to the firewall, are about 3/4 inch, and should not be pinched. Instead, remove the clamps at the firewall and join the hoses so antifreeze still circulates.
