How do you replace a heater coil in a 1987 mercury grand marquis?
Dec 30, 2006 at 7:23 AM
The part is a heater core, not a coil. Access requires removing the entire plenum box. Use a Chilton manual for the full procedure; a similar job can take several hours.
The owner asked how to replace the heater coil on a 1987 Mercury Grand Marquis. Experts corrected the name to heater core, said the plenum box must be removed to reach it, and recommended a Chilton manual. One expert said a similar 1986 Town Car job took about seven hours.
