HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mercury
Marquis
Engine Cooling
Leak
SPONSORED LINKS
Gran Marquis 92 - coolant leak
CHAS
MEMBER
1992 MERCURY MARQUIS
I have a coolant leak that's dripping from behind the engine (before the firewall). The car doesn't over heat and this only happens when pressurized.
Oil is fine.
Are there any hoses in that area of the engine?
Or is this a gasket leak?
If gasket - can I use one of those leak stoppers?
SPONSORED LINKS
Tuesday, April 24th, 2007 AT 4:36 PM
MERLIN2021
MECHANIC
I would stay away from sealers. They clog the heater core. Could be a heater hose, Have a pressure test done to pinpoint it!
Friday, April 27th, 2007 AT 2:03 PM
Please
login
or
register
to post a reply.
Related Leak Content
1999 Mercury Marquis Coolant Leak
Hello, My Car Has A Coolant Leak And I Have To Keep Adding Coolant Every 200-300 Miles. Recently Me And My Dad Replaced The Alternator...
Asked by
Stevo388
1 ANSWER
1 IMAGE
1999
MERCURY MARQUIS
VIDEO
Cooling System Pressure Test For Leaks
Instructional repair video
GUIDE
Coolant Leak Symptoms
When your car begins to leak coolant the first indicator is the engine will start run hot and possibly overheat. This will be noticed by the driver by observing the...
1983 Grand Marquis Coolant Leak
I Can Just See Coolant Bubbling Out Of A Small Hose Next To The Block Behind The Radiator. This Could Be A Heater Hose. Does It Snake...
Asked by
kurt mcvay
1 ANSWER
1993
MERCURY MARQUIS
1996 Mercury Marquis Loss Of Coolant
My 96 Mercury Has Had The T-stat Replaced With A Factory Unit And A New Rad Cap But I Still Push A Lot Of Coolant Out The Expansion Bottle...
Asked by
amazedref
1996
MERCURY MARQUIS
How Much Coolant Do I Add?
1997 Mercury Grand Marquis 4.6 Liter Mileage: 48,000. When Replacing The Engine Coolant As Suggested By The Owners Manual At 48,000 Miles...
Asked by
2CP-Archives
1 IMAGE
1997
MERCURY MARQUIS
Water Pump Bypass Hose
Asked by
lewisg12
1 ANSWER
1994
MERCURY MARQUIS
VIEW MORE
SPONSORED LINKS
Online car repair manuals
