1996 Mystique lower radiator hose
1996 ALL OTHER MAKES ALL OTHER MODELS
DIAMONDAVE
I have a 96 Mystique 2.0 for my son to drive, and the lower radiator hose ruptured the other day in the driveway. I got the replacement hose from the dealer, it is a spider looking thing with about 6 "legs" on it. It is the hose that runs from the filler tank to the radiator and pump, etc. I got to all the connections except the water pump hook-up. How in blazes are you supposed to get to the thing? I can't even get my hand down to the clamp, let alone get the thing off. Thanks-
Mar 19, 2007 at 9:16 AM
2CARPRO JACK
  • 11,533 POSTS
Start pulling accessories off until you have accss
Mar 19, 2007 at 11:59 AM
DIAMONDAVE
Was going to do that today, but the power steering pump is on top, and the a/c condenser is below, and I'm not sure if both of them off would give me enough room. Plus, the main belt will have to come off, I was hoping to get a more direct answer than a "poke and hope".
Mar 19, 2007 at 12:44 PM
GROVER805
i have the same probelm with my bros merc.(its also a 96 mercy mystque, make a long story short, the merc overheated in the freeway and we trired to take it off but with the limited time and location we had to get it towed....we couldent take it off, at the location, but yea i agreeed with you its a spider looking thing and hard to get to, my bro is going to start working on it and if there is succsess ill keep you updated, on how he did it and all. from what i saw it looks like you have to take out the exhaust mainfold heat shield and if there is still no room you got to take of the a/c pump off,
can you tell me how much the raditor hose cost?
jose
Mar 25, 2007 at 4:01 PM
DIAMONDAVE
I ended up taking it to a local guy I have used before after the massive response from my first post. Anyway, no thanks to this site, you have to pull the top motor mount loose, and the power steering pump to get at it, and possibly some other misc. items. It is about a 3+ hour job according to my mechanic. He also used regular clamps instead of the spring clamps they provide. The hose was $83. from my friendly Ford dealer. The dealer said originally it was about $400. for them to do the whole thing. Hope this helps.
Dave
Mar 25, 2007 at 11:38 PM
