How to Replace a Car Radiator Hose
Most radiator hoses are made out of silicone based rubber that offers resistance to hardening and cracking. Hoses can also show signs of bulging when they get close to failure, others can fail with no warning. High quality radiator hoses have multiple-ply construction with a fabric mesh reinforcement depending on the application.
Hoses Need to be Replaced When
  • Showing signs of bulging
  • Cracked and dry
  • Hoses are more than 8 years old
Tools and Supplies Needed
  • Flashlight
  • Jack stands
  • Floor jack
  • Coolant
  • Hose clamps
  • Replacement radiator hose
  • Fluid catch basin
  • Pliers/channel locks hose clamp removal tool
  • Screw driver set
  • Pick Tool
Best Practices
  • Always clean the hose fitting before installing the new hose.
  • Recheck the cooling system after a couple of days to ensure proper operation.
  • Use new hose clamps.
Let's Jump In!
Open the radiator cap to release any residual pressure and to allow the coolant to flow freely when drained.
removing radiator cap
Locate the radiator drain plug which is where the system coolant will be drained from, some cooling systems do not have a drain valve, the lower radiator hose should be used to drain the system.
locate drain valve
Loosen the drain plug allowing the coolant to flow into a catch basin, tighten the drain plug once the coolant has completely drained.
drain coolant
Identify the radiator hose that needs to be replaced.
upper radiator hose
At each end of the hose clamps are used to secure the hose to the radiator and engine. Use pliers, channel locks or a hose clamp installation tool can be used to loosen the clamp, a twisting motion will help loosen the seal of the hose.
removing hose clamp
Watch the Video!
Please watch this video of the job being done, then continue down the guide to glean additional helpful information.
Remove the remaining hose clamps at the opposite end of the hose.
removing hose clamp
After the hose clamps have been removed from the clamping area, use a pick or screw driver to "break" the seal by forcing it between the hose and fitting.
hose removal tool
Grasp the hose and twist the hose which will fully release the hose seal.
twisting hose remove
The hose will pull off the fitting, a small amount of coolant maybe present which is normal. A small amount of coolant can be trapped on top of the closed thermostat.
hose removed
Match the new radiator hose to the old hose to ensure a proper installation.
new radiator hose
After transferring the hose clamps to the new hose and cleaning fitting ends, push the new hose onto the fitting while squeezing the clamp open, repeat this for action the opposing hose end. Replace any clamps that are broken or worn.
install new radiator hose
When installing the hose clamps position the clamp in front of the fitting ridge, this ridge is designed to help the hose and clamp stay secure under pressure. The alignment of the clamp should be "square" (not crooked) to hold pressure needed to successfully seal.
clamp position
Once the new hose or hoses have been replaced, refill the radiator with coolant. Start the engine and allow to warm up to operating temperature which will allow the thermostat to open, continue adding coolant until the level is between the indicator lines on the coolant reservoir.
refilling coolant
 Reinstall the radiator cap and tighten, allow the engine to run while checking for leaks. If leaks are present release the system pressure and reposition the clamp.
reinstalling radiator cap
Questions?
If you have a car repair question, you can ask the 2CarPros community for help. We hope this guide helped you understand the repair. Please visit our 2CarPros YouTube channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
