1996 Isuzu Rodeo Coolant Flush
1996 ALL OTHER MAKES ALL OTHER MODELS
BEDNARCZYK
I am trying to flush my cooling system and the Haynes manual says there are coolant drain plugs on both sides of the engine block. I've drained what I can from the radiator plug but can't for the life of me find the engine block drain plugs. I think I've only got about 1/3 of the coolant out and want to finish the job. Anyone know where they are?
Jun 14, 2006 at 12:25 PM
JOUGH626
  • 55 POSTS
Remove your thermostat. Leave the upper radiator hose on. Stick a garden hose in the upper radiator hose. Turn on the garden hose. All the coolant will be flushed out. I hope this helps.
Jun 22, 2006 at 2:06 PM
Suggested Repair
Remove the thermostat, leave the upper radiator hose connected, insert a garden hose into that hose, and run water to flush the remaining coolant from the engine.
Conversation Summary
The owner of a 1996 Rodeo 3.2L drained the radiator but could not find the engine block coolant drain plugs and still had most of the coolant in the system. An expert recommended removing the thermostat and flushing the system by running a garden hose through the upper radiator hose.
