1993 Mercury Sable Heater Core Removal
SNIPPYBEAR
How do I removal the heater core from a 1993 Mercury Sable Wagon 3.8 engine..mileage 200,00 +
Oct 5, 2007 at 4:42 PM
FAIRRACING31
  • 150 POSTS
Snippy, You will need to remove your entire steering colum and dash to where you will have nothing but firewall, the last one I did took about 7hours. Unless you have some experience I would not recomend you do it. It would take me an hour to type the step's needed for the removal.
[quote:70866e6245="Snippybear"]How do I removal the heater core from a 1993 Mercury Sable Wagon 3.8 engine..mileage 200,00 +[/quote:70866e6245]
Oct 16, 2007 at 11:53 AM
Suggested Repair
Accessing the heater core requires removing the steering column and dashboard down to the firewall. Plan on about 7 hours. This is not recommended without prior experience; have a shop do it if you are not comfortable with dash removal.
Conversation Summary
The owner asked how to remove the heater core on a 1993 Mercury Sable wagon with a 3.8 engine and over 200,000 miles. The expert said the steering column and dash must be removed down to the firewall, the last job took about 7 hours, and it is not recommended without experience. Detailed removal steps were not provided.
