Mercury Sable Heater Core Replacement
MISSYLOVINYA
How do you replace the heater core?
Nov 27, 2006 at 11:45 AM
CATCH_15
  • 250 POSTS
The heater core is located behind the dash towards the passenger side. Usually, the whole dash has to be loosened in order to reach the core. It will have two heater hoses attached to it. You may have to loosen the clamps on the other side of the firewall under the hood to free up the core. Make sure you drain the coolant first though.
Dec 2, 2006 at 6:46 AM
Suggested Repair
Drain the coolant first. The heater core is behind the dash on the passenger side and usually requires loosening the dash. Disconnect the two heater hoses, loosening the clamps at the firewall under the hood if needed, then replace the core.
Conversation Summary
The owner asked how to replace the heater core on a Mercury Sable. The expert said it is behind the passenger-side dash, usually requiring the dash to be loosened, and that the two heater hoses and firewall clamps must be freed after draining the coolant.
