1986 Mazda B2000 Cruise Hesitation
Good luck,
Tony.
This could be a good posiblity
Cosmo..Mazda Tech
Cosmo...Mazda Tech
Suggested Repair
Have a Mazda dealer replace the carburetor idle mixture solenoid, identified by two green wires at the top of the carburetor. There is no reliable test; an older TSB covers this warm-engine cruise hesitation. After replacement, the carburetor and mixture settings must be reset by someone familiar with Mazda carburetors.
Conversation Summary
A 1986 Mazda B2000 owner reported hesitation, shaking, and jerking at about 2400-3300 rpm while cruising at steady throttle, only after the engine warmed up, and suspected the EGR system from a TSB. Other owners suggested air-cleaner reed valves, the distributor vacuum-advance diaphragm, a used carburetor, spark-plug installation, or cleaning reed-valve filters. A Mazda technician said the symptom, including a stumble near 65 mph, matches a faulty idle mixture solenoid that cannot be tested and should be replaced with a full carburetor mixture setup afterward.
