1986 mazda b2000, 181,000 mi
BOND343
  • 5 POSTS
truck starts and runs great, but then dies out of nowhere. it will always start back up, but it usually takes a five to ten minute wait. it is completely eratic, sometimes i drive it and have no problems, and sometimes i am sitting on the roadside wondering how far the truck will go before it dies again. i have replaced the whole ditributor and plug wires, and the truck still runs the same.
Jan 17, 2007 at 4:06 AM
  • 75,988 POSTS
[quote:9c93af97aa="bond343"]truck starts and runs great, but then dies out of nowhere. it will always start back up, but it usually takes a five to ten minute wait. it is completely eratic, sometimes i drive it and have no problems, and sometimes i am sitting on the roadside wondering how far the truck will go before it dies again. i have replaced the whole ditributor and plug wires, and the truck still runs the same.[/quote:9c93af97aa]
Try the EGR open it up and clean the carbon, then comeback
Jan 17, 2007 at 5:45 PM
BOND343
  • 5 POSTS
EGR has been checked and is fine. fuel line and filters have been checked. also, it is not vapor lock.
Jan 18, 2007 at 11:40 AM
  • 75,988 POSTS
[quote:5a3a35a770="bond343"]EGR has been checked and is fine. fuel line and filters have been checked. also, it is not vapor lock.[/quote:5a3a35a770]
Try the fuel pump relay if it has one-also check the actual fuel pressure when it dies out it shouldn't lose all the pressure within 10mins.Check your fuel pump connector-
Jan 18, 2007 at 11:50 AM
COSMO
  • 347 POSTS
Is your truck and auto or a 5spd?
changed the hole distributor? you mean the whole thing not just the cap and rotor right?
Check the coil for leakage and corrosion on the bottom of it.
HAs a new gas tank been installed recently?
Cosmo...Mazda TEch
Jan 18, 2007 at 12:26 PM
BOND343
  • 5 POSTS
truck is a five speed, whole distributor changed, no new gas tank, have tried pouring small amounts of gas into carb when truck dies to no avail.
Jan 18, 2007 at 3:04 PM
COSMO
  • 347 POSTS
Well then take a look at that coil.
I am also wondering what the condition of the sending unit in the tank is. Sometimes the sending unit gets small pin holes in the lines that cause the fuel pump/ carb to suck air into the lines causing problems.
Cosmo....Mazda TEch
Jan 20, 2007 at 1:16 PM
  • 75,988 POSTS
[quote:22bbce77ab="bond343"]truck is a five speed, whole distributor changed, no new gas tank, have tried pouring small amounts of gas into carb when truck dies to no avail.[/quote:22bbce77ab]
Your missing spark-otherwise it will fire up when you prime it.
Check for power at +pos term. of coil-if present-now crank engine over and while a voltmeter or test lite at the -neg terminal-VM or testlite should be fluctuating/blinking-if not check the ignitor-if it is blinking check the rotor,cap, and coil wire and the coil primary/secondary resistances.
Also it might have an external resistor that's inline with the primary circuit.
HTH-Good Luck!
Jan 20, 2007 at 1:48 PM
