1987 Mazda Truck Truck dies out
165,000 MILES • 4 CYL • 2WD • MANUAL
KAMU11
My truck has an unusual problem of sometimes starting up or it takes a long time to get it started. Once I get it started it will run fine for awhile and then it will just die out and it happens even if I am on the freeway. It also tends to run on the hot side. I have replaced the fuel filter already and am wondering maybe if I should also change the fuel pump. Maybe it is another problem that I do not understand. Any and all suggestions will be greatly appreciated.
Thank You
Jan 9, 2008 at 1:14 PM
  • 75,988 POSTS
Try checking the carb choke if its sticking closed-should fully open after 3 mins of warm up. Also check the fuel pressure then comeback.
Jan 9, 2008 at 4:25 PM
