I am not getting 12 volts to the fuel pump. I see in wiring diagram that there is a Three Point Relay before the fuel pump, where can I find the location of the relay? Can I just run a hot wire to pump that is only hot when the ingnition is on, or does the relay turn the pump on and off depending on the amount of fuel the carb. Needs. Thanks bunches
Thursday, May 3rd, 2007 AT 7:50 PM
