1986 Mazda B2000 Carb Backfire
BRAD54
I just purchased a 1986 b2000. It had over 300,000 miles. I replaced the engine with a low millage Japan (2.0) import engine. The truck has new plugs, new vacuum hoses, new O2 sensor. The truck runs well when warmed up at moderate to full throttle. There is a small backfire up thru carb when accelerating from idle. There is also a single electrical connector that goes from the side of the carb that isn't hooked up. It has a yellow blue wire and I believe it is coming from the choke. I have a service manual and I cannot find out if it is a test connection or if it needs to be connected to something else.
Thanks All
Brad
Sep 9, 2007 at 9:01 AM
MERLIN2021
  • 17,250 POSTS
Timming chain may need looking at or you have a worn cam lobe!
Sep 9, 2007 at 9:09 AM
Suggested Repair
Inspect the timing chain and check for a worn cam lobe, which may cause the backfire through the carburetor when accelerating from idle.
Conversation Summary
The owner of a 1986 Mazda B2000 with a replacement 2.0 engine reports a small backfire through the carburetor when accelerating from idle, although it runs well when warm at moderate to full throttle. New plugs, vacuum hoses, and an oxygen sensor are installed. An unused yellow-and-blue connector at the carburetor, possibly related to the choke, is also noted. The expert suggests checking the timing chain or a worn cam lobe.
