2003 Mazda Protege Dash Gurgling
LHARDEE1
2003 Mazda Protege ES, 63000 miles . Hi, I have had several problems. First, on a trip 350 miles from home, my fan belt broke. Was towed and had fan belt and timing belt replaced. Was released and towed again because the radiator was blown. Had the radiator and thermostat replaced the next day. All codes were fine. Got home. In city traffic, car was overheating, displaced by heater, got to a mechanic and was told that the mechanics probably didn't release the air in the line and was low on antifreeze and added 1/2 gallon of antifreeze. Few days later, engine light comes on. Spark in 3rd was arcing and may have gotten wet from fan backflow from radiator and needed new plugs and wires and maybe the coils. Fine. Plugs should have been replaced at 30k . Wires and plugs replaced, coils cleaned and ok. Before I took it in for the tune up, I noticed that on morning start up that there was a gurgling (stomache rumbling) sound under the dash. It runs fine and doesn't do it after running during the day. Also noticed water leakage/ dripping when parked that doesn't seem to contain coolant. Mechanic doesn't know what it is but after test driving thought he still smelled antifreeze and that I should watch it. It remains full and is not overheating. I have to do another 700m roundtrip this weekend with kids. Thoughts?
Jul 14, 2007 at 5:16 PM
  • 75,988 POSTS
[quote:9df6ebbeaa="lhardee1"]2003 Mazda Protege ES, 63000 miles . Hi, I have had several problems. First, on a trip 350 miles from home, my fan belt broke. Was towed and had fan belt and timing belt replaced. Was released and towed again because the radiator was blown. Had the radiator and thermostat replaced the next day. All codes were fine. Got home. In city traffic, car was overheating, displaced by heater, got to a mechanic and was told that the mechanics probably didn't release the air in the line and was low on antifreeze and added 1/2 gallon of antifreeze. Few days later, engine light comes on. Spark in 3rd was arcing and may have gotten wet from fan backflow from radiator and needed new plugs and wires and maybe the coils. Fine. Plugs should have been replaced at 30k . Wires and plugs replaced, coils cleaned and ok. Before I took it in for the tune up, I noticed that on morning start up that there was a gurgling (stomache rumbling) sound under the dash. It runs fine and doesn't do it after running during the day. Also noticed water leakage/ dripping when parked that doesn't seem to contain coolant. Mechanic doesn't know what it is but after test driving thought he still smelled antifreeze and that I should watch it. It remains full and is not overheating. I have to do another 700m roundtrip this weekend with kids. Thoughts?[/quote:9df6ebbeaa]
Get it recheck if you still smell anitfreeze could be the heater core leaking.
Jul 14, 2007 at 5:28 PM
Suggested Repair
Have the cooling system rechecked. If an antifreeze smell remains, suspect a leaking heater core.
Conversation Summary
A 2003 Mazda Protege had a broken belt, radiator and thermostat replacement, low coolant after air was not bled, and ignition work. The owner reports a gurgling sound under the dash on morning startup, water dripping when parked that does not appear to be coolant, and a possible antifreeze smell, though the coolant level stays full and the engine is not overheating. The expert advises rechecking it and says a lingering antifreeze smell could indicate a leaking heater core.
