1999 Mazda Protege Startup Squeal
PRADHAN_TUSHAR
HI,
My 99 Protege makes a loud squealing noise on when it is started after it has been parked for two or three hours.
A mechanic attributed it to loose belts (not sure which ones) and tightened them but that hasnt helped at all.
Any ideas / help will be appreciated.
Thanks.
Jan 9, 2006 at 7:29 AM
COSMO
  • 347 POSTS
Most likely you need new belts...alot of times even tightening old belts will still end up with a squeal...Also using a low quality belt will have the same effect...you best off to use a good Mazda belt...or a gates belt...steer clean of poly cog, they tend to stretch
Jan 9, 2006 at 1:28 PM
Suggested Repair
Replace the drive belts with quality Mazda or Gates belts rather than only tightening the old ones; avoid poly-cog belts, which tend to stretch and can continue to squeal.
Conversation Summary
A 1999 Protege squeals loudly on startup after sitting for two or three hours. A mechanic tightened the belts, but the noise continued. The expert advised replacing the belts with a quality Mazda or Gates belt and avoiding poly-cog belts that stretch.
