2003 Mazda Protege Cold Rattle
CORN123
I have a 2003 Mazda protege 5 and I have a little problem. It has 57,000. When I start the car in the cold and i drive it makes a rattleing noise (squeking) when I stop or slow RPMs. Then it goes away when I speed up. After the car warms up the whole rattleing goes away! Any ideas of what could the cause be?
Jan 14, 2007 at 12:45 PM
COSMO
  • 347 POSTS
Sounds like you are describing a loose heat shield around the exhaust (usually the front Cat or front pipe)
Cosmo....Mazda TEch
Jan 14, 2007 at 9:35 PM
Suggested Repair
Inspect and secure or replace a loose exhaust heat shield, typically around the front catalytic converter or front pipe.
Conversation Summary
The owner of a 2003 Mazda Protege with 57,000 miles reports a rattling or squeaking noise during cold driving at low RPM or when slowing. The noise stops when accelerating and disappears after the car warms up. A Mazda technician suggested a loose heat shield around the exhaust, usually at the front catalytic converter or front pipe.
