Hey Roy, looks as if my message I sent yesterday got lost. I checked all relays in trunk, all were good. I always keep a 12 volt battery in car. They all clicked. I followed red wire that didn't have any power to the pull down motor. That thing hasn't worked in 10 plus years. I also used test to check for short. What I did was disconnected positive terminal clamped test light to battery the with point end on positive cable. Test light was not light. Then I reversed test light clipped to cable then point on battery. Then it light up. Pulled fuses one by one, light never went off. It's raining out, sure you are sick of me by now. Still no closer to problem. If it was the module, wouldn't the door locks not work either. The inside button, does that use the antenna, or use the module at all. Thanks bud.
Wednesday, March 25th, 2020 AT 2:34 PM
