Air Conditioner Problem?
EDWARDCODE
  • 7 POSTS
Thank you very much for all of your critical help
Monday, July 13th, 2020 AT 1:39 PM (Merged)
MSHT58
  • 1998 LINCOLN TOWN CAR
Air Conditioning problem
1998 Lincoln Town Car V8 Two Wheel Drive Automatic 86.000 miles
hot air all the time
Monday, July 13th, 2020 AT 1:47 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Suspect blend door
check for codes
Simultaneously depress OFF and FLOOR buttons, then press AUTOMATIC button within 2 seconds. Display will show a pulse tracer going around the center of the display window for up to 30 seconds while test is running
Code Number Circuit Test
24, 25 Temp. Blend Door Actuator
30In-Vehicle Temp. Sensor Short
31In-Vehicle Temp. Sensor Open
40, 42 Ambient Temp. Sensor Shorted
41, 43 Ambient Temp. Sensor Open
50, 52 Sunload Sensor Shorted
115 Engine Coolant Temp. Sensor
This could be the blend door or it may just be low on Freon. We should check and make sure the compressor is coming on, and if it is then we need to check the pressures with a gauge set.
Here is a guide that explains this and how to evacuate and recharge the system. I also attached what the pressures should be based on ambient temperatures. Let us know what you find. Thanks
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Monday, July 13th, 2020 AT 1:51 PM
