1998 Lincoln Continental Hesitation
SAKMAN
98 Lincoln Continental 120k V-8
I have a major valve cover gasket leak that will be fixed on Friday.
The car has a hesitation in the engine (like a miss) when going up a hill and just trying to maintain speed.
Could this be a vacuum issue related to the valve cover gasket?
I had 4 coils replace in the past year. Could it this problem be another coil going bad?
Thanks,
Steve
Nov 19, 2007 at 10:00 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the v/c gaskets are leaking oil down into the plug wells causing misfires.
Nov 20, 2007 at 3:47 AM
Suggested Repair
Inspect the spark plug wells for oil from the leaking valve cover gaskets. Clean the wells and replace the valve cover gaskets so oil does not foul the plugs and cause misfires.
Conversation Summary
The owner of a 1998 Lincoln Continental reports engine hesitation like a miss when climbing hills or holding speed, plus a major valve cover gasket leak and recent coil replacements. The expert says oil leaking from the valve cover gaskets into the plug wells is likely causing misfires.
