1996 Lincoln Continental P0308 Misfire
MIKE HOOPER
I have a 96 Lincoln continental V8 with 140,000 miles on it with a p code falt of p0308, cylinder 8 misfiring, what are some causes for this problem?
Oct 4, 2007 at 3:20 AM
SERVICE WRITER
  • 9,123 POSTS
A misfire on the eighth cylinder only, may be a bad plug wire, bad or dirty connection of the coil post where the wire attaches, a bad plug, injector problem. The first thing I would look at is a vacuum leak however. Spray some carb cleaner around the intake manifold and listen for an idle change.
Oct 4, 2007 at 3:23 AM
Suggested Repair
Check for a vacuum leak first by spraying carb cleaner around the intake manifold and listening for an idle change. Also inspect the cylinder 8 plug wire, coil-post connection, spark plug, and injector.
Conversation Summary
The owner of a 1996 Lincoln Continental V8 with 140,000 miles reports code P0308, a cylinder 8 misfire, and asks about possible causes. The expert suggests checking a vacuum leak first, then a bad plug wire, poor or dirty coil-post connection, bad spark plug, or injector problem.
