1998 Lincoln Continental Injector 6 Misfire Fix
ROD2639
I have a 1998 Lincoln Conntinental and I had Auto Zone and Advance Auto to diagnose the problem and both said is "injector six in missifiring" I had the oil,spark plugs and fuel filter changed and also two ingnition coils as well. I need to know were in injector six located so I can correct the problem and replace it.
Aug 15, 2007 at 3:34 AM
2CARPRO JACK
  • 11,533 POSTS
#6 will be the second one back on the drivers side as you stand in front of the car looking at the engine.The injector is on top near the coil, on the upper part of the engine
Aug 15, 2007 at 9:21 AM
Suggested Repair
Locate injector 6 as the second injector back on the driver's side when facing the engine from the front. It sits on the upper engine near the coil; replace it if the misfire diagnosis is confirmed.
Conversation Summary
The owner of a 1998 Lincoln Continental was told by two parts stores that injector six is misfiring. Oil, spark plugs, the fuel filter, and two ignition coils had already been replaced. The expert said injector 6 is the second one back on the driver's side, on top of the engine near the coil.
