1992 Lincoln Continental Injectors Won't Fire Fix
DBMSTR124
  • 6 POSTS
I have a 1992 Lincoln with the 3.8L v6. I replaced the ignition module on it. It used to crank but never start. Once I replaced this it started and drove at 33 MPH top speed and that was it. Now I try to start it and the injectors won't fire. I pulled one off and hooked jumpers to it and you could hear it fire. I can put starting fluid in the intake and get it to fire then obviously no fuel, so it dies. What electrical problem is this? How do I fix it? Thank you...p.s. I did check all fuses...thank you
Sep 19, 2007 at 12:07 PM
  • 75,988 POSTS
[quote:a474e1b5de="dbmstr124"]I have a 1992 Lincoln with the 3.8L v6. I replaced the ignition module on it. It used to crank but never start. Once I replaced this it started and drove at 33 MPH top speed and that was it. Now I try to start it and the injectors won't fire. I pulled one off and hooked jumpers to it and you could hear it fire. I can put starting fluid in the intake and get it to fire then obviously no fuel, so it dies. What electrical problem is this? How do I fix it? Thank you...p.s. I did check all fuses...thank you[/quote:a474e1b5de]
Check the fuel pressure make sure its on specs. No problem with pressure-could be the computer not getting a crank signal from the distributor pick-up or the crankshaft position sensor and not energizing the injector/s or a problem with the computer's quad driver/s.
Sep 19, 2007 at 12:26 PM
  • 75,988 POSTS
Inbox :: Message
To: rasmataz
Posted: Thu Sep 20, 2007 1:56 pm
Subject: lincoln injectors
where is the crankshaft sensor and where can I buy one, its a hard part to find? thank you
_________________
Josh
The CPS its on the upper front right side of engine also called CID sensor.
Good Luck!
Sep 20, 2007 at 10:12 AM
DBMSTR124
  • 6 POSTS
[quote:f8d3c5526b="rasmataz"]Inbox :: Message
To: rasmataz
_________________
Josh
Good Luck![/quote:f8d3c5526b]
I still haven't found the sensor, do you think you could take a picture of its location? Where can you buy one, I have looked on the internet and they are not easy to find. I appreciate it...thank you
Sep 23, 2007 at 7:17 AM
  • 75,988 POSTS
What model is it Town Executive/Continental?
Sep 23, 2007 at 7:43 AM
DBMSTR124
  • 6 POSTS
[quote:fc4d23aabf="rasmataz"]What model is it Town Executive/Continental?[/quote:fc4d23aabf]
Its a continental
Sep 23, 2007 at 1:33 PM
Suggested Repair
Verify fuel pressure is within specification. If pressure is good, check that the computer is receiving a crank signal from the distributor pickup or crankshaft position sensor (also called the CID sensor, on the upper front right of the engine) so it can pulse the injectors. Also consider a failed computer quad driver.
Conversation Summary
The owner of a 1992 Lincoln Continental 3.8L said the car would crank but not start until the ignition module was replaced, after which it ran but only to about 33 mph. It now cranks with no injector pulse. An injector clicks when jumped, and starting fluid will fire the engine briefly before it dies from lack of fuel. Fuses were already checked. The expert advised checking fuel pressure, then a missing crank signal from the distributor pickup or crankshaft position/CID sensor, or a computer quad-driver fault. The CID sensor was described as on the upper front right side of the engine, and the model was confirmed as Continental.
